Can somebody please help! I'm Baffled!
Old 01-21-2011 | 09:24 AM
mOjO_JK's Avatar
well alrighty then, guess ill try those options...hopefully it wont be nothing serious but rather something stupid
sixty5vdub's Avatar
I would say it is most likely a shifter cable problem. Either the cable broke, came off of the shifter inside the Jeep, or came off of the lever on the transmission under the Jeep.
I would check the transmission lever first, as you won't have to take anything apart to see it. Climb under your Jeep. Look at the driver's side of the transmission, in the area near the front of your front driveshaft boot. You should be able to look up and see where the cable attaches to the transmission.
If the cable popped off of the transmission, try to pop the end of the linkage back onto the transmission lever. Try reaching up between the transmission and driveshaft, and push the transmission lever towards the back your Jeep as far as it will go. If it still in R, it should click one time while pushing the lever back. That will get you back into P. The end of the linkage should now be lined up with the transmision lever, and should pop onto it.
If it still attached to the transmission, then check the shifter end of the cable by removing the console. Not sure about the steps involved with that, so I will let others tell you about that.
Good luck!
Anthony
Old 01-22-2011 | 12:27 PM
mOjO_JK's Avatar
Ok....so Anthony was right!...the lever under the Jeep is fine....its popped back into P....she starts just fine but now the shifter just slides....so obviously something broke in the center console....probably due to the cheap plastic parts Jeep uses?...anyone have the steps how to remove the center console?
Old 01-22-2011 | 02:45 PM
mOjO_JK's Avatar
Just wanted to say thank-you to everyone's replies and help!...I got it done...you were a lot of help Anthony!...I'd you are ever in El Paso ill buy you a beer!...it turns out after I removed the center panel I saw the problem right away...the cable had popped out from the lever...so nothing broke?!...yay!!!
Old 01-22-2011 | 03:24 PM
sixty5vdub's Avatar
Glad I could help! You might want to wrap a couple of wire ties around the linkage and lever, to make sure it doesn't pop off again!
Anthony
Old 01-23-2011 | 01:53 AM
TINMAN080's Avatar
Remember folks to allow the cable linkage Time to do it's job before moving the shift lever again. Rapid shifts that move the cable in it's housing too quickly can cause the ends to break or come loose. You can cause more pressure on the cable ends than they are designed to take- hence ''pop-off'' or breakage.
Old 03-06-2011 | 06:38 AM
cajunaviator's Avatar
I had the same problem with my 2007 auto trans. The plastic clip on the end of the shift cable popped off of the shift lever in the center console. I pushed it back on and everything worked fine. My dealership said they had never had any reports of this happening. It has come off two other times since. Now I just check to see if it is firmly connected from time to time.
Old 03-06-2011 | 09:02 AM
lopezv123's Avatar
Originally Posted by wazooz2424
x2. doesnt sound like an electrical issue, so disconnecting the battery wont do any good. if the lever moves and the transmission doesnt shift, its most likely the shift cable. try the 4lo trick.
X3 on the shift cable.
Old 03-06-2011 | 09:04 AM
lopezv123's Avatar
Originally Posted by mOjO_JK
Unfortunatly I am work, I will try some of the suggestions afterwards, but I forgot to add that, on the dash panel its still in R, but my lever is in P on an incline (driveway)....I was in a hurry and stupid me may have shifted back into park without completing it when I truned it off....the jeep can still roll reversed....so its not in Park...a friend told me to get push onto level ground and turn the ignition to on and try to put the lever into reverse to "pop" back it back and then put it into park
Don't try to POP anything into gear when u have an auto. Chock a rear tire and crawl under to take a look at the linkages.
Otherwise shift the transfer case into neutral and tow it home.
Quick Reply: Can somebody please help! I'm Baffled!
