Can the ESP be fully turned off?
Old 10-04-2010 | 02:08 PM
  #31
aermotor's Avatar
Originally Posted by dirtyboyjustin
in the post to wire the kill switch it mentions the need for two wires why is this is one a ground or am i wiring to pieces of wire to the splice? Can someone please clear this part of the process up for me im a little confused? Am I making two splices on the purple wire or one? Any help here would be great. I have the locker mod done on my '07 but need to get this ESP kill done before I can use it.
You need two wires if you are wiring in a switch.... one for each side that you cut. You cut one wire and cut it in half thus creating two wires. So now you need two new wires to connect to each end and the your switch.
Too bad I still can't find the right wire to make this work for me... Strangely enough while driving the other day out of the blue the ESP/BAS lights came on all by themselves and now don't come on at all. Grrrr.
Old 10-05-2010 | 01:34 PM
  #32
dirtyboyjustin's Avatar
so if you are using a splice clip you only need a single wire since you are not cutting the original okay and then the other switch terminal can be grounded is this correct to assume
Old 01-05-2014 | 12:13 PM
  #33
MasterClay's Avatar
Does anyone know, will this mod still work with a 2012?
Old 01-05-2014 | 12:46 PM
  #34
Newbeme's Avatar
There is a lot of info in this thread, https://www.jk-forum.com/forums/jk-w...riteup-260247/
Old 01-20-2014 | 12:07 PM
  #35
Hack12's Avatar
Here is a chart detailing what the different factory ESP turn off methods will actually do. Click image for larger version
Here is the aforementioned traction control hokey pokey kill dance that was mentioned earlier in this thread and is detailed in the final box of the above chart. Click image for larger version
Quick Reply: Can the ESP be fully turned off?
