cam position sensor
Standing in front of the Jeep, stick your hand on the upper radiator hose and follow it to where it connects to the engine. Look at the engine directly under that and slightly to the passenger side. You'll see a wiring harness going to the sensor housing held in by one bolt. You can't miss it.
the code we are getting is p0300....which I know what it says...but since we have checked and double checked everything we are thinking it could be a bad sensor here????
The computer should be able to see if the cam sensor is bad, and throw a code for it.
How is the engine running?
Anything that affects the speed of the crankshaft can cause a misfire DTC.
When a Misfire is detected for a particular cylinder, the PCM will shut down that cylinder's Injector Control circuit.
Did you look at these things:
Turn the ignition off.
- Visually inspect the engine for any of the following conditions.
- Worn serpentine belt
- Binding Engine-Driven accessories: A/C Compressor, P/S Pump, Water pump.
- Misalignment of the Water pump, P/S Pump and A/C Compressor pulleys
- Corroded PCM power and ground circuits.
- Improper CKP, CMP, MAP, and TP Sensor mounting
- Poor connector/terminal to component connection. i.e., CKP sensor, Fuel Injector, Ignition coil, etc.
- Vacuum leaks
- Restricted Air Induction system or Exhaust system.
- Internal engine component failures.
For P0300, Multiple Cylinder Misfire, did you cover all the items below?
Possible Causes
(F342) ASD RELAY OUTPUT CIRCUIT
INJECTOR CONTROL CIRCUIT
COIL CONTROL CIRCUIT
IGNITION WIRE
SPARK PLUG
IGNITION COIL
FUEL PUMP INLET STRAINER PLUGGED
RESTRICTED FUEL SUPPLY LINE
FUEL PUMP MODULE
FUEL PRESSURE LEAK DOWN
FUEL INJECTOR
ENGINE MECHANICAL
POWERTRAIN CONTROL MODULE (PCM)
- Vacuum leaks
Possible Causes
IGNITION WIRE
SPARK PLUG
IGNITION COIL
FUEL PUMP MODULE
FUEL INJECTOR
ENGINE MECHANICAL
(PCM)
(PCM)
Everything I do seems to work for about a month, then the engine light comes back. p0300,
Well, knock out all the items you can in post #6.
There is a lot of troubleshooting in the FSM for this code. The bad thing is it takes the dealer's scan tool to do most of it.
If the cam sensor and crank sensor are not too expensive, you could always try replacing them.
Otherwise, you have to take it to someone with a scan tool.
....and the wife probably wouldn't like us drinkin beer and talkin Jeeps. I'm sure I would, though. LOL
