A/C question
A/C question
On my new 2011, whenever I start the Jeep the air comes out of the floor vents for 5-10 seconds before it switches up to the dash vents. This is after the 5 or so second delay for the blower motor to run following startup. It does this with the A/C on or off and the selector switch set to the dash vents. Is this normal? I am worried that this will eventually cause the flapper door (or whatever you call it) that directs the airflow in the ducting to fail since it is switching vents on every startup. It did not do this in my 2010, it would come out immediately from the selected vents.
Like your 10. My 10 Rubi doesn't do it. I would have to guess that when your Jeep is off you're losing vacuum which causes the flapper door to default to the lower position. Then, in the 5-10 seconds it takes to build vacuum, it switches back to the dash. I bet you have a leak in a line or in the controller. I would take it in under warranty.
Mine has a delay also..maybe because of the auto temp feature?
That sounds like it makes sense kik.
I am not worried about the delay with the blower when starting the Jeep...that sounds like a feature that makes sense...let the engine get oil to the heads and such before engaging the load of the A/C. But I am worried about the flapper door. Think I will call the dealership.
Thx,
Paul
Thx,
Paul
Thx,
Paul
Thx,
Paul
