A/C heat wont turn on.
So I've been having this problem with my Heat and A/C lately. It turns on and off when I hit big bumps in the road or when I slam my door or hood. As of now it isn't on at all and didn't come on this morning (6 degrees here doesn't make for a fun drive this morning). Im going to check the fuses when I get home but looking for other solutions if the fuses are good.
As in the fan/blower won't come on or the fan will come on, but no heat or AC, just pushes air?
Sounds like you have a pinched wire that is now probably broken. Have fun tracking it down.
Well start with checking to make sure everything is still connected from the HVAC controls and then the connections to the blower. If everything looks good, start checking wires with a volt meter until you find the issue. Good luck.
