Buying a used 3.8L JK
Old 09-04-2015, 02:00 PM
Riflejk's Avatar
D35 who knew! Mine had a d44 and 4:10 gearing because it was optioned with the tow package. The d30 up front didn't last though.
Old 09-04-2015, 07:13 PM
nthinuf's Avatar
Originally Posted by Riflejk
D35 who knew!
lol, yeah, there aren't a lot of them out there. I think I have only seen maybe 4 posts from people who actually won that particular lottery, three 2dr and one 4dr.
Old 09-04-2015, 10:08 PM
jsukey's Avatar
Here is the build sheet for my '07 JK Sahara, paying attention to the writing in bold:
According to our records, your vehicle was equipped from the factory
with the following:
Sales Code Description
*E5 Prem Cloth Low-Back Bucket Seats
-JJ Dark Khaki/Medium Khaki
APAS Monotone Paint
BABS 160 Amp Alternator
BC2S 600 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BNMP Traction Control
BNSP Electronic Roll Mitigation
BPTP Hydraulic Assist Brake Booster
BRWS 4-Wheel Disc Brakes
CACS Low Back Bucket Seats
CAGS Easy Access Passenger Seat
CDBS Reclining Front Seats
CDHP Driver Height Adjuster Seat
CFMS Rear Folding Seat
CGWS Advanced Multistage Front Air Bags**
CGXS RR Head Restraints Outboard Seating
CJ1 Supplemental Frt Seat Side Air Bags
CKES Front Seat Area Carpet
CKFP Rear Seat/Wheelhouse/Cargo Carpet
CLC Front Floor Mats
CLMS Sport Bar w/Full Padding
CUFS Full Length Floor Console
CURS Rear Compartment Covered Storage
DBBC All Manual Transmissions
DEH 6-Speed Manual NSG370 Transmission
DHES Command-Trac Shift-on-the-Fly 4WD
DJRS Next Gen. Dana 30 Solid Front Axle
DMF 4.10 Rear Axle Ratio
DRZS Next Gen. Dana 44 HD Rear Axle
DSA Anti-Spin Differential Rear Axle
DS7S Conventional Differential Frt Axle
EGT 3.8L V6 SMPI Engine
GBBS Tinted Windshield Glass
GCCP Plastic Front Door Window
GCDS Deep Tint Sunscreen Windows
GCH Half Metal Doors with Locks
GNAS Rear View Day/Night Mirror
GNDS Driver Side Sun Visor
GNYS Passenger Side Sun Visor
GTVS Swing-Away Mirrors
GWK Sunrider Soft Top
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGAS Hood Insulation
JA2S Premium Instrument Cluster w/Tach
JCDS 100 MPH Primary Speedometer
JE8S Manual Door Locks
JFJS Temperature & Compass Gauge
JF8S Manual Windows
JHAS Var Intermittent Windshield Wipers
JJFS Single Low Note Horn
JJJS 12V Auxiliary Power Outlet
JKAS Glove Box
KXSS RADIANT SILVER WRANGLER BADGE
K5DS BLACK FENDER FLARES
LMAS Halogen Headlamps
LNJS Fog Lamps
LPSS CHMSL Lamp
MBAS Black Front Bumper
MB5S Black Rear Bumper
MFRS Black Front Frame Overlay
MFTS Body Color Grille
MRKS Tubular Side Steps
MT2S Trail Rated Badge
MVCS Jeep Badge
MYJS Sahara Badge
NAA Federal Emissions
NF2S 18.6 Gallon Fuel Tank
NHMP Speed Control
PX8A Black Clear Coat
QX8S Black Clear Coat
RC9S Alpine Premium Audio System
RDDS Fixed Long Mast Antenna
RESS Uconnect 130 AM/FM/CD/MP3
RSC SIRIUS Satellite Radio
SBAS Power Steering
SCLS Leather Wrapped Steering Wheel
SDUS Heavy Duty Suspension w/Gas Shocks
SHAS Front Stabilizer Bar
SHCS Rear Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TT6 P255/70R18 OWL On/Off Road Tires
TZBP Bridgestone Brand Tires
VJKA Dark Khaki Soft Top
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
WPB 18X7.5 Aluminum Wheels
XCAS Occupant Classification System
XEES Fuel Tank Skid Plate Shield
XEFS Transfer Case Skid Plate Shield
XEWS 2 Front & 1 Rear Tow Hooks
XGWP Stain Repel Seat Fabric
XJFS Tethered Fuel Filler Cap
XJGS Non Locking Fuel Filler Cap
XPFS Protective Coating and Remover
X81S Instrument Panel Parts Module
X83S Front End Parts Module
X86S Complete Chassis Parts Module
X88S Tire & Wheel Parts Module
X9AP For More Info, Call 888-539-7474
X92S Complete Body in White Parts Module
X94S Complete Painted Body Module
X97P 1-Year Service Provided by SIRIUS
YAAS Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
Old 09-04-2015, 10:11 PM
jsukey's Avatar
BTW, my '07 had right at 100,000 miles on it when I bought it 2 years ago. I was burning through a quart of oil ever 1000-1500 miles. I changed the PCV valve, and it stopped. I don't lose any oil whatsover between my 3k mile oil changes. I'm at 120k miles now, and still running strong!
Old 09-04-2015, 10:49 PM
Former Member
101gargoyles's Avatar
Originally Posted by Blue
This isn't correct. My 2007 X 2dr was built in July 07 and had a D44 rear and 4.11 gearing. Some of the very early 07's had the D35s.
And yes that is correct. 44's were an ordered option. Rubi was equipped with them as stock.
Old 09-06-2015, 06:51 AM
gohard's Avatar
My 07 JKU X was the biggest POS I ever owned. Burned more oil then gas, and leaks everywhere. Head gasket was leaking, steering box was leaking....all expensive fixes. The new engine they put in under warranty started burning oil again after 15K miles. Glad is gone. Almost made me give up on Jeep.
Old 09-06-2015, 02:30 PM
jsukey's Avatar
How a vehicle is treated has a lot to do with how it's going to hold up when it gets older.
Old 09-06-2015, 07:37 PM
Blue's Avatar
Actually, it is not correct. All JK's except for a few early '07's had Dana 44 rears from the factory and D30's in the front. Mine had 4.1 gears and wasn't special order. The 4.1 gears were the upgrade, not the D44 as per the window sheet. That at least 2 2drs with that gearing on the lot. What the Rubi's had/have is the D44 front and rear with Lockers and the lower geared T-Case. The started making 3.73 standard in the Rubi with 4.1 being an upgrade and 3.73 the lowest gear option in the non-Rubi. As pointed out a couple of posts ago, those rigs with the D35 don't seem to turn up very often.
Old 09-06-2015, 07:39 PM
Blue's Avatar
That is very true!
Old 09-07-2015, 11:13 AM
Former Member
When I get my replacement desktop up for a scan I'll forward an 07 sales brochure. If you didn't order a build for yourself and bought off the lot the non standard equipment will be listed on the build sheet as options. Not standard.
Quick Reply: Buying a used 3.8L JK
