Brake system issues *need help*
So my abs esp and traction lights came on. Ran the abs scanner and came back for abs pump fault. I checked my fuses and my j6 (40a square fuse abs pump) was blown. Bought a couple replacement fuses. Replaced and they immediately blew as soon as I plugged in new fuse. does anyone know what would be causing the over amperage? I’m not sure exactly what this system is looking for and or doing power wise????
I'd like to start looking into this issue, but I have no idea what you have for a vehicle.
Also, it would be helpful if you posted the code you got from the scanner.
