Brake rotor Warning
Old 08-31-2009, 02:05 PM
Hitch Buddy's Avatar
Originally Posted by JackMac4
this post is misleading because it sounds like you're saying the brake rotors were bad, but you also said you damaged them because you couldnt get them off. Which is it exactly?
You must brake or ride your brakes an aweful lot to a) need new pads at 34,000 miles and b) need to rotate your rotors.
I have read people changing them at 32,000 for the rear and 40,000 for the front,
The rotors should not have been that hard to remove.SoI damaged them getting them off.I live in a big city lots of stop and go.that means I apply the brakes a lot and I drive fast!
Old 08-31-2009, 02:07 PM
Originally Posted by Blackjp4dr
I got 48000 miles on my brakes and still work great, maybe I should chck them. Also on other vehicles I never removed rotors to change pads. Is this a new kind of set up?
After taking caliber off to change pads and after inspecting rotors i saw and felt they need to be cut or turned whatever you guys wanna call it.
So when taking them off I damaged them because they were soooo hard to get off.
Old 08-31-2009, 02:10 PM
Originally Posted by HappyCurmudgeon
Sorry you had trouble, but I gotta ask...
why did you need to remove your rotors to change your pads? Did they need to be turned?
Ther rears have the parking brake internal drum/hat thing, ... was that your hangup?
Well the parking brake was not an issue I adjusted them all the way out first.
Don't know why they were frooze on.But the Pass front was the same way.I took a base ball bat jammed it against the front diff and behind the rotor started the car cut the wheel into it to pop it off...This took many attempts.
Old 08-31-2009, 02:12 PM
dlincoln91's Avatar
i had to change my pads and rear rotors at 15k due to sand from my farm
Originally Posted by sukemecuke
Please tell me you didn't have the parking brake on.....
WOW NO response needed here
Old 08-31-2009, 02:14 PM
Well I don't suppose you had trouble getting yours off seeing they only had 15,000 on them.
Old 08-31-2009, 02:45 PM
dlincoln91's Avatar
yeh mine slipped right off but still i pressure washed my brakes and everything after everyweeked of work and hunting and that still happened
Old 08-31-2009, 03:06 PM
JeepDoc's Avatar
Next time you have a hard time with rotors use an air hammer..
Go between the studs works great. Vibrations break them free. I use this method allot works great.
Or use a hammer hitting the same..between studs. If you use a hammer put the lugs back on so you dont damage threads.
Old 08-31-2009, 08:49 PM
JeepDawg's Avatar
Glad to see I wasn't the only one that uses a technique other than a baseball bat.......
Old 03-12-2010, 10:13 AM
SCF
SCF's Avatar
Just ran into this problem. Won't budge despite my valiant attempts with the star gear. Will be doing this tonite.
Thanks!
Quick Reply: Brake rotor Warning
