Brake grinding....
Old 03-25-2010 | 05:55 PM
middlezg's Avatar
Default Brake grinding....
When i go around a curve or get off an exit ramp where most of the weight is shifted to the left side, my front left brake makes a grinding sound that would be usually reserved for worn out brake pads. Its not my pads, they look brand new, the rotors look fine also. Any suggestions? Its an 07 2 door X
Old 03-25-2010 | 06:29 PM
ronjenx's Avatar
Have you checked the lug nut torque?
Jack it up and see if there is play in the wheel bearing.
Old 03-25-2010 | 06:49 PM
uup4it's Avatar
Might be an over active ESP, mine does that when I try to take a curve faster than the jeeps' computer wants me to. Could also be faulty. Check for troubleshooting codes.
Old 03-25-2010 | 08:05 PM
middlezg's Avatar
i jacked it up a few days ago to check it out and there is no play in the wheel, its not the ESP (the esp is much more pleasant and usually does a good job of slowing me down) also it feels like if i pushed down on the brake pedal while its doing this, it might rip something out
Old 03-26-2010 | 08:10 AM
Bradlybob's Avatar
Veteran: Navy
Might it be the unit bearing failing? When you're turning and putting a side load on the bearing it may be making the noise. I'd pull everything off that corner and really examine the unit bearing and then reassemble it all and make sure all of the bolts are torqued to spec.
Or if it's under warranty and unmodified I'd let the service dept figure it out.
Old 03-26-2010 | 09:58 AM
Newtybar's Avatar
I think you solved one of my worries. Whenever I take a sharp turn my steering freaks out and the wheel wiggles. I think this might be the ESP freaking out.
Old 03-26-2010 | 12:04 PM
uup4it's Avatar
Yep, that's the ESP trying to put the brakes on for ya. It seems to think I am going too fast around curves or turns and dictates the breaking sensation. Maybe I am going too fast, , you must be going too fast too
Old 03-26-2010 | 12:06 PM
mikesjk's Avatar
Next time you make a sharp turn and it does this take a look at you gauges. You should have some lights come on to tell you if its your ESP. The car with squiggly (sp) lines.
Old 03-26-2010 | 07:33 PM
CreepyJeeper's Avatar
X2...my thoughts exactly.
Old 03-27-2010 | 11:00 PM
middlezg's Avatar
nope, i've experienced the esp..i know the light
