Brake Failure WTF
Brake Failure WTF
I took a drive up to the Eisenhower tunnel temps dropped down to 15deg I come up on a rig with his hazards on I went to hit my brakes and nothing I got off at the nearest exit and no busted or damaged lines so I turn around to head back to the house and the brake light comes on and still no pressure I made it home using my gears because my F e-brake is out right now as well, did the temp and alt have something to do with this or did they just FAIL
First of all take it easy for awhile, your guardian angel has been workin' overtime and needs a nap. I am assuming you have checked to make sure you have brake fluid in the resivour and have decided to bleed all four breaks after filling it up...
Trust me captain im taking a break the JK in sitting in the garage for a while Well I found the problem fellas when I pulled over to check the lines everything was covered in ice and water and couldnt make out the leak if there was one. Well I just got back home from dinner in my other (vehicle) and noticed my jeep in the driveway with brake fluid coming from the driver side rear tire the freaking brake line was rubbing my tires how did I miss that this must of happen when the trac-bar mount went or when I was welding either way im one lucky bastard
