Black Rear Diff fluid
Old 06-29-2010 | 03:02 PM
JK-Tex's Avatar
I changed mine at 15,000 miles. The front was honey-like. The rear was darker, but hardly tar-like or black. Good luck figuring out what's wrong. Hope it's not too serious.
Old 06-29-2010 | 03:13 PM
nthinuf's Avatar
Originally Posted by Avalanche40
I thought the exact same thing, that they did not change the fluid, but I know they did. There was a new gasket installed, which meant they had to take the cover off, which would empty the diff. I wonder if they cleaned it or not when the cover was off, or just slapped the cover back on and refilled it.
What was the reason for pulling the cover? New gears? Checking out a noise? Just an xxx mile inspection?
Old 06-30-2010 | 07:52 AM
Avalanche40's Avatar
They were doing the 30k service.
Old 06-30-2010 | 08:18 AM
JC JK's Avatar
I would pull the cover and check everything! Black and low miles don't sound right! I allways pull my covers first time. and then add the best AMSOIL! then do the normal fuild chang when needed.
Old 06-30-2010 | 11:32 AM
Detonatorunlimited's Avatar
Recently took the Jeep in for an oil change and they found the rear diff fluid to be black. It had been only 5k miles since the Diff fluid was changed during the 30k service. The front fluid was perfect. The only difference is I now have a 2.5in lift and 33's installed shortly after the 30k service. So only 5k with the lift installed. So I have a couple of questions?
1) What would be causing this? Shop told me could have just been super dirty, or have a bearing going bad.
2) Should I worry much about it? Shop told me it will be fine until next oil change and have it looked at then!
The shop changed the oil for free, so that was a pleasant surprise.
https://www.jk-forum.com/forums/show...ght=diff+fluid
check this out, i had the same question awhile ago from what i gather its because mine hasnt been cleaned properly
Old 06-30-2010 | 02:44 PM
Just checked out the link, thanks for the additional info.
Shop said they cleaned everything with the cover off, but since it is just words spoken by a dealership, I will take it at face value. Hopefully all will be well at the next oil change for the Jeep, they will check the diff again.
Old 06-30-2010 | 05:06 PM
nthinuf's Avatar
Could it be the actual oil they used?
I seem to recall a thread a while back indicating that dealerships (or a specific dealership, at least) used big barrels of lower quality oil. As opposed to the higher quality stuff most of us grab off the shelf...
