Bent front axle, what next?
Went in to get aligned and the axles bent. Got the wheels rotated and i guess its been that way for a while and now i get death wobble after rotation. So un-did the rotation but now my expensive KM2s are trashed and i dont want to do the same to another pair till i fix the axle.
What all do i need to know to get this fixed? what is exactly bent? the housing? the shafts? can i put the same shafts in a new housing? What parts do i need to buy? should i upgrade to a dana 44/60?
Im fairly clueless on the subject. I did a search on quadratec just to see whats there and a new dana 44 is aroudn $2500... really wishing i hadn't bought my hardtop a few months ago...
My buddy bent the rear axle on his FJ cruiser. The repair shop put a jack under the rear diff and lifted the back end off the ground, started the truck, and put it in gear. We watched the tires rotate and he showed us that the tire was not wobbling as it rotated so he could just get a new axle housing to fix it. He said that if the axle itself was bent the tire would wobble as it spun.
Not sure if this helps in your case but my buddy ended up doing what the guy said and just buying a housing and replacing all the internals from the old one into it.
Are the gears still in good shape? If so, they can go in the new housing, along with the other axle shafts and the ends.
Or look for a cheap take-off from someone that upgraded to a PR44.
Or just move to a PR yourself.
I have a Dana 30 now with 35s. I go out often and do as much as i can but by what i consider hard or rough i haven't done the worst yet so im not sure where or how i bent it.
With the PR44 or a Dana 44 would i be able to use the shafts and internals from my dana 30? or will i have to buy all new stufff to go along with it?
you really can't get any meaningful advice without an accurate description of the damage. The phrase ''bent axle '' can mean several different things....It can mean the alignment guy doesn't have a clue how to align the jeep, or doesn't really know what's wrong. A bent knuckle could be the problem, bent centerlink, pitman arm, the box splines could be twisted. As peviously stated the ''c's'' could be bent, or an axle tube, or the axle shaft flanges themselves. Are the front wheels negative (in at the top), positive(out at the top)? Is the wheelbase equal on both sides? Is the steering wheel centered? Is the Jeep sitting at equal heights left and right? A bent tube can be staightened, a bent cast iron part (other than the C's) cannot.( and be safe) Does the jeep track straight, or wander left to right? Does it pull to one side or the other? As you can see, there are many questions to be answered before the term ''bent axle'' can really be applied....Best of Luck!
