Battery Warmer & Engine Block Heater
I just added the mopar engine block heater this past week. I live in the Chicago area and I added it because our winters are getting worse. Plus this will help with warming and efficiency during the cold winter months.
I grew up in Minnesota, lived in Montana for 5 years, Idaho, and am now in Iowa, and I can tell you it gets colder in Minnesota and Iowa than it will in Wyoming for prolonged periods of time. You will be just fine without the engine block heater, and without the battery blanket. You may want to look into the remote start because that would be nice for the cold mornings so you don't need to go out to warm it up before you get in.
Yeah I was always told that you are supposed to start it right up and drive off and not let it "warm up" as this was somehow bad for it.
thats weird b/c ive always been told the exact op. even though i usually just start her up and go. but have heard its better to let it sit for a few min then go. i dunno
Letting it idle to warm up is nice for the driver and passengers, but it comes at a cost.
It takes longer to warm up, so it is running rich for a longer period, which washes the cylinder walls and allows gas to get past the rings into the crank case. When idling with cold oil, less oil is splashed onto the bottoms of the pistons, reducing the amount of oil getting to the cylinder walls.
There are more reasons to start and go. Do a search.
The block heater is standard equipment on our Canadian JK's.
You would only need to use the block heater is you anticipate overnights less than 0 F, and even then only 2-3 hours before the start is useful. If you leave it plugged in all night it is really just a waste of energy.
I have learned a few things living in and around Winnipeg, MB! (-25F January)
