Baja Stories
I'm going with this one and I will report back with the results.
https://www.rockauto.com/en/moreinfo...13604&jsn=1479
I clicked on that link above and had to laugh at the Cali warnings that are on just about everything to cover their legal butts. Geez, it's nylon!
Attention California Customers - WARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov
It worked but I had to trim one side of the bushing with a razor blade and taper it. Definitely not a perfect fit but seems like it may work and hold. I think the proper fix is the $65 cable and assembly for sure if this falls off again
Tackling the C1405 - Transfer Case Range Position Sensor Circuit High code today. It seems like step one is to at least remove the sensor and inspect plus inspect the wiring but its right on top of the transfer case and I can't really get a good look at it. Does anyone know if this can actually be pulled without pulling the driveshafts and lowering the transfer case?It seems like it could be possible if it were your second time doing the job for sure.
It may be covered under lifetime powertrain but maybe not. I could get that nonsense that it's considered a sensor and therefore only internal parts get replaced.
This is the only part listed on Rock but I am not sure with a Sahara 3.73 if it's the correct one but Im pretty sure that would have nothing to do with it and the TC is standard on the 4x4 package all around.
https://www.rockauto.com/en/moreinfo...=1441555&jsn=9
For $65 I'd give it a try myself to make sure 4x4 is good to go. That would really suck if you get somewhere and then cant get out.
Side note, pretty sure there is no locking tab -- just press and pull.
Just seeing if anyone completed this job before I go crazy with it.
That sensor is a stepped resistor. Cant remember the ohm value but each step tells the computer what position you are in by providing a different resistance value. At 200k miles I would just change it but do what MrT suggested and clean it up as well.
