Back Seat-Belts Lock Up
At least the rubber stop would be adjustable, and could be considered "permanent" as long as you left it on.
Okay, same question with different cause:
I unbolted the rear belts (floor and pillar) to Herculine the tub. The anchored end of the belts bolts to the deck, the working end to the rollbar (vader helmet). Trying to re-install, I could not get ANY slack in the spring-wound ratchet, let alone enough to re-anchor them. Since I pulled the rear seat, it's not a huge issue, but I would like to put them back on someday.
I know why they do it. It is because the belt is to short. I am a bigger guy and when i ride in back it locks if i lean up to talk to people in front. someone at DC wanted to save money and cut a corner and used less belt. I have been working on an idea to fix this as well as the incline of the seat.. Right now still on drawing board got to find hardware that would hold up in a wreck. if you was to move the retractor up 6 inches it should be fine for the fattest guy. My problem is finding hardware to do this and be safe. Plus im on the 0 dollor budget so it might be a week or too till I get the stuff I need. I will do a full write up on it once it is done. nother chose is to move the retractor and guide forward and that would work.
This is what I was picturing in my twisted mind. With a little imagination, one could make a similar home-made clip.
I was out with my in-laws in the back of my Jeep today and they had this exact problem.
I'm pretty sure that the driver's seat doesn't do this, who would allow a child in a child seat to drive?
I wonder if I could find a couple of seat belts that would normally go into the driver's position and install them else where? It would seam like it would be cost effective to use the same seatbelt every where, but have a way to disable the lock feature on the drivers seat.
Sorry to resurrect this really old thread, but I know a pretty good solution to this that is actually for use on seat belts (won't damage the belt, or void any insurance things). How about just using a locking clip? You know...the metal ones that come on child restraints for the purpose of keeping seat belts in older vehicles from loosening. I'm pregnant so I use a locking clip on the lap portion of my belt to keep it from getting uncomfortably tight.
You can get them for around $3 at ToysRUs, Walmart, pretty much anywhere that sells baby stuff.
