Axle u joint
Old 06-12-2010, 11:12 PM
CA-JK's Avatar
Originally Posted by adamisadam
can someone explain perhaps with pics, abouting welding the caps, pros & cons, and what happens if it breaks on the trail. I'm very mechanical but don't know what everything is related to the fron axle assembly.
TIA
Pros: It keeps the caps from flying off.
Conn: it is a PITA to fix on the trails unless you have a grinder or a complete new assembly.
Old 06-12-2010, 11:16 PM
mmccurdy's Avatar
Originally Posted by CA-JK
It becomes one piece and hard to replace.
I thought about this, but every time I've lost an axle on the trail, it's been *because* of the u-joint cap, so it seems like a worthwhile tradeoff. I carry spares anyway, so I can pull the whole thing and just replace it on the trail, then when I get back home, I can grind off the tack and replace the joint to use as a spare next time around.
Old 06-12-2010, 11:25 PM
CA-JK's Avatar
True, it's an easy fix at home with the right tools but it can be a pain on the trail. I agree that you could use a once broken axle a spare once you take it home a grind off the tack. I just wouldn't recommend it unless you carry a spare shaft while you’re on the trails.
Old 06-13-2010, 04:56 AM
adamisadam's Avatar
are both front axles interchangeable?
Also, where's the best place to read about how to learn how to make this repair? Is there a Chiltons yet for JK's? I'll start looking.
Old 06-13-2010, 07:54 AM
backwoodjk's Avatar
I have never tried to remove a welded cap on the trail, but I think you might be able to get through the tacks with a good cold chisel and hammer.
Old 06-13-2010, 08:13 AM
opdsgt's Avatar
I have but one thing to say to the OP: get a set of RCVs!!
Old 06-13-2010, 08:16 AM
Moochie's Avatar
Maybe, some day soon.
Old 12-19-2010, 10:00 PM
I know this is an old thread but should the rear axle shaft caps be welded too or just the front?
Old 12-19-2010, 10:10 PM
JCKnauer22's Avatar
there are no u-joints on your rear axleshafts. that is, unless you have rear steer
Old 12-19-2010, 10:23 PM
Ok thanks. Definately no rear steer here
Quick Reply: Axle u joint
