Axle u joint
Conn: it is a PITA to fix on the trails unless you have a grinder or a complete new assembly.
I thought about this, but every time I've lost an axle on the trail, it's been *because* of the u-joint cap, so it seems like a worthwhile tradeoff. I carry spares anyway, so I can pull the whole thing and just replace it on the trail, then when I get back home, I can grind off the tack and replace the joint to use as a spare next time around.
are both front axles interchangeable?
Also, where's the best place to read about how to learn how to make this repair? Is there a Chiltons yet for JK's? I'll start looking.
I have never tried to remove a welded cap on the trail, but I think you might be able to get through the tacks with a good cold chisel and hammer.
