View Poll Results: Has your axel seal failed? Take the freaking poll!
Yes one has!
190
39.09%
Both failed!
50
10.29%
No, nothing yet.
235
48.35%
Whats an axel seal?
11
2.26%
Voters: 486. You may not vote on this poll
Axel seal problem poll.
Old 05-06-2013, 05:03 AM
  #121
Bushmaster's Avatar
My 2010 had this problem on the drivers side. Then the stealer ship fixed it and the passenger side leaked so I took it back and they fixed that too.
Old 05-06-2013, 05:18 AM
  #122
Maertz's Avatar
My driver side just started leaking...
Old 05-06-2013, 01:07 PM
  #123
JK_hammer_47's Avatar
09 UL both fronts replaced at 70000KM due to leaking. Rears still going strong
Old 05-06-2013, 05:33 PM
  #124
Jdowse's Avatar
07 X with just over 70k, 33" tires with spacers and 3" lift. Front pass seal just started leaking. What are people paying to have this replaced and do most of you have them do the other side as well while they are in there? What does that cost? Thanks.
Old 05-06-2013, 06:09 PM
  #125
macanto66's Avatar
08 x JKU. I had a rear fail around 15,000 dealer replaced under warranty no mods. a front around 25,000 dealer replaced under warranty and around 65,000 the dealership noticed both fronts a tiny bit wet and they decided to monitor it until it became an actual leak. at my 5 year inspection about 82,000 miles they replaced both front seals under warranty.
Old 05-08-2013, 05:28 AM
  #126
Green-man's Avatar
38000 km and both fronts leaking. 265/75/16 tires with procomp 7069 backspaced rims. Mild offroading like slow trails and a few hills. One or two deeper puddles. Also ripped my axle breather off not sure when or how, could this be the culprit? Water in the diff?
Old 05-08-2013, 06:20 AM
  #127
yo_marc's Avatar
My axles seals are quirky. I had my passenger front start leaking after a u-joint replacement. Had the dealership fix it. It started leaking again - brought it back to dealer and said they would look to replace the axle shaft, at my cost. I'm stubborn so I pulled the axle to see if it was damaged. I put the axle back in, and the leak stopped. It's been bone dry for about a year now.
I noticed my drivers rear seal leaking later last fall. I've been shopping around for parts (and a press) to do it myself, but I kinda stalled on it. The leak has let up quite a bit. Not an urgent problem at this point.
132,xxx miles. 07.
Old 05-08-2013, 06:08 PM
  #128
JK_Crawler's Avatar
My 08 JKU Rears were replaced last month @ 43k, I have an extended warrany and only paid a $50 deductible so I didn't bitch. If it wasn't I'd just replace them myself since I'm a mechanic.
2" spacer lift, 33s witch aftermarket rims
Old 07-01-2013, 09:09 PM
  #129
Just_Q's Avatar
I noticed my driver's side leaking last week when I was installing my bumper. Dealer replaced it today. 2013 w/ 8200 miles.
Old 07-01-2013, 09:14 PM
  #130
k0260's Avatar
Recently installed a lift for a friend on their new 09 Sahara 4 door with 65k miles. Passenger side front axle seal was blown, leaking bad
Quick Reply: Axel seal problem poll.
