View Poll Results: Has your axel seal failed? Take the freaking poll!
Yes one has!
190
39.09%
Both failed!
50
10.29%
No, nothing yet.
235
48.35%
Whats an axel seal?
11
2.26%
Voters: 486. You may not vote on this poll
Axel seal problem poll.
Old 06-01-2011, 10:03 AM
  #91
mrktwatchr's Avatar
08 - 90K leaking drivers rear side .....
Old 06-01-2011, 04:05 PM
  #92
rickl's Avatar
Default 195 000 km no leaks yet
few other issues but at 195 000 kilometers on odo no axle seals yet
I did install outer axle tube seals at approx 100 000km when I did front axle u-joints so may have leak cannot see,oil level has not dropped though
Old 06-01-2011, 05:57 PM
  #93
JK Forum Regional Rep
familytime's Avatar
51,000 and counting on our '07 JK,yet i already planning to up-grade front axle shafts and install axle tube seals
Old 06-01-2011, 06:02 PM
  #94
familytime's Avatar
Originally Posted by cmpmacchia
OK, Ok, I'll start it.
How many of you had an axle seal fail.
If so, please post your mileage and mods if any.
Is everyone using stock diff covers or have you up-graded?If up-graded,don't measure your level by the after market fill hole,i have found this adds too much oil to the carrier,thus over filling and leaks will happen
Old 06-01-2012, 01:53 PM
  #95
redunlimitedguy's Avatar
08 jku 6sp. No off roading yet. I am the second owner. Only 35k miles. Being the second owner jeep dealership told me they would not replace the front passenger side seal under warranty. Is there an outside seal on the front axle. Everything is stock by the way.
Old 06-03-2012, 09:02 AM
  #96
Justinn407's Avatar
08 jku 32k miles, replaced both rear seals and bearings pursuant to finding rear wheels to have play and leaking oil... Went ahead and did shafts too.
Brought it to the dealership they advised me that I've owned my jeep for greater than 3 years and basically turned me away.
T/F 4" lift
T/F 2" spacer
M.o.r.e. 1" b/l
38x13.5x17
Old 06-03-2012, 11:57 AM
  #97
jsears's Avatar
Both rears have failed. Only mod to that axle is gears.
One front and the only mods to those are: Evo sleeves and gears.
Old 06-03-2012, 12:37 PM
  #98
gunbo75's Avatar
97,000 miles and all good.
Old 09-03-2012, 10:11 AM
  #99
kkjk's Avatar
118,000, drivers rear leaking. (stock) About to find a write up and fix them.The Tracy ca dealer where i bought it wouldn't piss on my JK if it was on fire..........
Old 09-05-2012, 04:30 AM
  #100
books450's Avatar
Bought my new 2012 a few weeks ago and it had 9 miles on it. I had a 300 mile drive back home and when I got home I noticed the passenger side rear seal leaking. Took it to the dealer he next day and they found that the axle bearing was put in backwards from the factory. It got a new bearing, seal, retainer and fluid. I now have 900 miles on it and no issues. I was pretty disappointed at first but I realize things do happen.
Quick Reply: Axel seal problem poll.
