Automatic transmission broken!
Okay so i just installed my new 3" lift and 33's and decided to test my rig out on some of my buddies trails. while wheeling i went the wrong way and got burried! i rocked my self out eventually and everything seemed fine for the rest of the time. howeveer when i got back out on the road i noticed that my AT would not shift into first or third it just stayed in second! so i tried putting it in first and no luck... and when it finally started upshifting on its own now it wont downshift on its own...so when i stop its still in overdrive and i press the gas pedal to takeoff it runs up to 3000 rpm and slams down all the way to first! any clues as to what is wrong and if it should be warrantied?
Update***
After sitting overnight i went outside to hobble it to the carwash and hose'er down but now in any gear selection (inclluding park) it goes forward! no leakage of fluid or dash lights!
transmission
I would have it delivered to screaming lizards. when my manual was messed up i took it to them. they doctored it up and took it to the dealership for me. $500 to screamin lizards $3200.00 covered under warranty when they took it in for me.
sounds like 2 problems harness damage and cable /arm bent or binding on tranny. If you rocked this back and forth for 20 minutes then you didn't do this tranny any good. A good tow strap will keep you out of this situation.. not preaching, okay? Best of luck!
