Auto Trans Oil Change - no more gear - Help
Hello. I change my transmission fluid yesterday on my 2008 Sahara Diesel Auto transmission. I changed also the 2 filters. I followed the write-up you can find here :
http://project-jk.com/jeep-jk-write-...ission-service
It is a real pain to get the 3 bolts in the rear of the pan... I am lucky to have a garage lift.
I put the 4 quarts of Mopar ATF+ oil and check the level as it is stipulated in the write up....
But now : no more gears. I can put in D - R - N - 2 - 1..... but you don't feel the transmission engaged.
I have check the shift cable. Everything works. I have check all the external sensors. Everyhthing there and tight.
I disconnected the battery for a night long in order to have the system reset. This morning I connect the battery.... but if the engine start alright, the transmission doesn't put in gear.
Is anybody has encountered this problem ?
My last solution will be to call a haul to my Jeep resseller.
Thanks if you have any idea.
what made you decide to change the fluid ? a problem or routine maintenance ? how many miles on your jeep ? recheck the level after you started it ? if not check again its probably low
My JK has 48 000 kms (30 000 miles). I have checked the level several time (I poured 6 Liters (6 quarts)).
raid? lol ....did your old fluid smell or look burnt? any debris in the pan ? sorry to ask so many questions jus trying to get an idea .did you drive it back home ? any symptoms after it cooled down ?
If you want to see what is my garage (I am in a club) goto http://www.univem-paris.com. You'll see plenty of nice 4x4 trucks and old jeeps.
Fab
I changed mine with the help of another member. It took 6.5 quarts to get the level back up to full. Did you measure how much you removed? Are you using Mopar fluid ATF+4, did you use a Mopar transmission filter and replace it exactly the way the old one was installed? I'll bet you are low on fluid if all else is ok.
I'll check with the Chrysler computer on tuesday to see if any error codes... It is very unusual. No Jeep forum report that kind of problem.
Thanks for your help.
I didn't measure how much i removed as I took a shower of it !. I used the Mopar ATF+4. use the tranmission filter exactly the way the old one was installed... I check several time the level of fluid.... It seems perfect.
I did that several time. so weird.
Looking at the fluid/filter change data in the factory service manual for the 545RFE, 5 quarts are required to refill the transmission.
Also, it gives a warning about the primary filter seal on the oil pump:
CAUTION: The primary oil filter seal MUST be fully installed flush against the oil pump body. DO NOT install the seal onto the filter neck and attempt to install the filter and seal as an assembly. Damage to the transmission will result.
That's contrary to how it's done on the 42RLE, as in the write-up you used.
I've never seen a 545RFE, so I don't know if this is as much a factor as the book says it is.
Anyway, you may not have enough fluid in it, (which is the most common reason for not shifting properly), or the filter may have been incorrectly installed.
