Anybody Else Have Hole in Interior Panel (found when removing carpet)?
Old 03-31-2008 | 06:11 PM
nickdz's Avatar
Default Anybody Else Have Hole in Interior Panel (found when removing carpet)?
Anybody else with a 2-door find a hole on the interior of the jeep when they removed the carpet? I would like to assume everybody's jeep has these (one on either side), but I've owned many jeeps before and never saw anything like it.
Nick
Old 03-31-2008 | 06:22 PM
saltman's Avatar
Mine has a big sticker in that spot
My Jeep's black. not that you can tell from the picture. Best paint job ever.
Old 03-31-2008 | 06:25 PM
nickdz's Avatar
Hmmmmmmm... crap. I really don't feel like trying to explain this to a dealership.....
Old 03-31-2008 | 06:27 PM
saltman's Avatar
Why worry about it. It probably has something to do with how they are assembled. Be happy you got paint on the inside. Did yours not have the stickers??? Mine has them all over the body. A few under the hood few at the rear. I was going to remove them when I Line-X soon. I am sure the stickers will fall off after it gets wet a few times.
Old 04-01-2008 | 06:47 PM
jelvis's Avatar
thats a mastic patch.put in while going down the line at factory. Used insted of foam to cover holes.
Old 04-01-2008 | 07:57 PM
mkjeep's Avatar
Carefull, may void the warrenty when you remove those. I'm sure this is the source of all esp problems
Old 04-01-2008 | 08:25 PM
Big D2's Avatar
You broke rule number 1. Do not take your JEEP apart!
Old 04-01-2008 | 08:29 PM
Thats where you put the dope.
Old 04-01-2008 | 09:26 PM
scouter4life's Avatar
is that were all the mysterious rattles are coming from?
Old 04-01-2008 | 10:33 PM
Gravel Gertie's Avatar
There is always Duct Tape if you pull it off and change your mind. Make Red Green proud!
Quick Reply: Anybody Else Have Hole in Interior Panel (found when removing carpet)?
