Any other "07"s need piston rings
#141
Originally Posted by JKlad
Although some motors have had the rings incorrectly installed on the pistons resulting in huge amounts of oil consumption, it seems many JKs do burn some oil. We are told by Chrysler that this is normal.
The common consensus on my local forum where this discussion is currently running seems to be that it's the thin oil Chrysler specifies mainly to increase mileage for their CAFE figures that is the problem. Of course many people have said that modern, high performance, tight-tolerance motors need the new, thinner oils to lubricate themselves properly and the myth that the Chrysler 3.8L V6 is one of these modern, tight-tolerance motors seems to have propagated here. The new Pentastar quad cam, VVT, high performance V6 may certainly be in this category however the JK's old fashioned, iron block, low-revving, single camshaft pushrod motor 20 years or more old in design certainly is not. One of the guys is an experienced mechanic who has examined the specs for the JKs V6 motor and is of the opinion that the tolerances are decidedly old-school & not particularly tight at all.
In reality 5w20 is a low viscosity winter-weight oil that is well suited to the North American and European winter climate however under harsh operating conditions 20 weight oil will burn off in a motor such as the low-tech 3.8L V6, particularly at prolonged highway speeds. Many people where I am have found that their oil consumption stops completely when they switch to 15w40 grade oil, which is far better suited to hot climates (5w20 isn't even available off-the-shelf where I am as it's considered too thin an application for hot climates, 5w30 being the thinnest oil available without special order).
#142
I'm shocked nobody has done a compression test. You can get a tester for $25 at autozone. Anyone have a manual with the acceptable range? I'm thinking 150-200 psi would show on a healthy motor.
#143
My JK is doing its oil consumption test. I wonder what they will do when they see it's burning more than 1 quart per 1000 miles.
#144
With the amount of oil these engines are burning, would they still pass federal emissions? If not, you may be able to get this taken care of through emissions warranty in some states.
#145
Even a cylinder leak-down test can be good on an oil burner.
#147
Only two people have bothered to look at their engine numbers, and post their engine's point of assembly.
#148
#149
bigf350sd I to love the Jeep but THIS IS SIMPLY RIDICULOUS
#150
I asked them when they replaced the rings if there was any damage to the cylinders, they said that they were fine, I also asked if there was any specifics on a break-in period for the new rings ie; keeping it below a certain RPM or speed they said no it will be fine.
