Another misfire post 2015 JKU
I've read a ton of posts and a ton of Google searches and have yet to find anyone with anything that has helped. I know a lot of people don't like to read long posts so I'll try more of a highlights format.
- 2015 JKU Penstar V6
- 85,000 miles
- Random codes showing misfires in different cylinders with accompanying engine hesitation
- Been in the shop 3 times so far and replaced all plugs, coils, fuel injectors, and left cylinder head.
- I went to school with the owner of the shop and have no reason not to trust him. Says they've done leak down and compression tests.
- Every time I get the Jeep back, it runs fine for a couple of days and then the codes and hesitation come back and don't leave.
The timing may be as simple as the computer is resetting while unplugged being worked in. Then the computer is taking a few days to relearn. System codes that are vague have to be present a few times before they pop. What codes are you getting? And why was the left head replaced? Was there a leak/bad valve seat found? Was/is it burning oil?
