Annoying noise/clunk in Steering Column
Old 11-12-2010 | 03:26 PM
  #291
hammer71's Avatar
Been there ...done that.It will return after a month or 2.Something in the fabrication is causing excessive play....this is just a quick fix that doesn't last.VERY frustrating as they should have a recall and replace them with something proper!!I will try the grease fix and report back.
Cheers
Old 11-12-2010 | 04:28 PM
  #292
Hellbound13's Avatar
Cheers
Exactly. X2
Old 11-13-2010 | 06:32 PM
  #293
db09JKU's Avatar
Had mine replaced 2 months ago. It's back.
Old 11-13-2010 | 10:56 PM
  #294
BlackDiamond's Avatar
You should try this: remove the lower intermediate shaft then put it back without replacing it with a new part. Tight the bolts and see what happens
Old 12-07-2010 | 04:48 PM
  #295
nakoma's Avatar
ok, this is my first post, so dont raise hell if i get it wrong. but i have the same noise. i had someone turn the steering wheel back and forth while i check for the noise. i found my noise to go away when i grabbed the steering shaft slip joint boot. thier is a little play in the slip joint causing my noise.
Old 12-23-2010 | 04:24 PM
  #296
Kozmotoo's Avatar
Default Fixed mine...
The dealer replaced the intermediate shaft in less than an hour under warranty with no questions asked. It resolved my clunking noise. This was about two months ago, so time will tell if the fix endures.
Old 12-23-2010 | 05:23 PM
  #297
Dronac's Avatar
I have the clunk but only in the summer when it's 90+ outside. I plan on injecting 5th wheel grease in the shaft boot and see what happens.
Old 12-24-2010 | 09:39 AM
  #298
drumnatural's Avatar
My conclusion is that it's heat related.
The cold weather along with 5th wheel grease and it's gone.
I noticed the same thing last winter. But once spring/summer arrived it was back.
Old 12-24-2010 | 04:04 PM
  #299
Peter01's Avatar
I only get it off road.
I call feel it happening.
Also on hotter days its worse.
Old 12-24-2010 | 08:30 PM
  #300
d2constable's Avatar
Default Tagged
Tagged for reference.
Quick Reply: Annoying noise/clunk in Steering Column
