Annoying noise/clunk in Steering Column
#291
Been there ...done that.It will return after a month or 2.Something in the fabrication is causing excessive play....this is just a quick fix that doesn't last.VERY frustrating as they should have a recall and replace them with something proper!!I will try the grease fix and report back.
Cheers
Cheers
#292
Cheers
Cheers
#294
#295
ok, this is my first post, so dont raise hell if i get it wrong. but i have the same noise. i had someone turn the steering wheel back and forth while i check for the noise. i found my noise to go away when i grabbed the steering shaft slip joint boot. thier is a little play in the slip joint causing my noise.
#296
Fixed mine...
The dealer replaced the intermediate shaft in less than an hour under warranty with no questions asked. It resolved my clunking noise. This was about two months ago, so time will tell if the fix endures.
