Amsoil Question
It seems like motorcycle guys swear buy it....but I run Harley Syn3. It is hard to find and I buy it from a local mom and pop place. It cost 11.99 a quart here in Northeast Georgia.
Originally Posted by dognights
I personally use Motul in all of my engines now. Proven history of extreme use products.
LOL, thanks for the info. I don't think I will ever get to my first oil change on my '12 JK. I was totally sold on Royal Purple, after hearing so many people rave on here about it. Then I read a thread where someone said that RP was accused of using dino oil and marketing it as synthetic and that they lied about other things. A few other people chimed in and agreed with the statement. A chart was posted that showed the results of oil tests on numerous brands and Amsoil was on top of each chart and the users in the thread seemed to overwhelmingly want Amsoil. Now I decide to go with Amsoil and then I hear this. Maybe I will just go with Mobil 1, or is there some bad crap about them too? So confused on what to do...
Probably best that you research, because everyone will have a good or bad opinion.
Originally Posted by JKRescue08
There will always be someone out there that doesn't like a product. I have used it for 10+ years in all of my vehicles and I wont use anything else. Contrary to what dognights said, Amsoil has one of the highest flow properties out there which makes it one of the best at transferring heat. Plain and simple, it's oil - it will not be the reason your car breaks down, you will have had other contributing factors.
In general. Very general it doesnt matter too much what kind of oil you use if you change it often enough.
With that said oil does a few tasks. First off it obviously lubricates obviously, but it is also used to absorb harmful gases, neutralize acids, act as a heat sink to direct heat away from moving components, and maintain surface friction.
There are basically 5 groups of oil types. These are grouped by what base is use to start with when making the product.
Group one is basic mineral based oil. Think cheap made in "china" oil sent to you in a cloned honda dirt bike motor. You dont want to use this
Group two is your typical "normal oil" base that you can find easily at someplace like walmart. Think normal valvoline 10w-30 your grandpa used in his old pickup
Group three is what some call synthetic oil. Group three is actually group 1 oil that is highly refined with additives. There is really a big debate on this as this group is not really a synthetic oil even thou companies like castrol and other label group 3 as synthetic oil.
Group four is a true synthetic oil base. Amsoil is a group four oil as well as many other popular choices people like to use that perform very well.
Group five is an ester based synthetic oil. This is a plant based product and has very high adhesion properties to metal. You will hear claims of how the produce actually fuses to metal surfaces, etc
The group rating of the oil in general has a direct relationship with the amount and quality of the additives that are also added. The higher the group number typically the higher the amount of calcium, boron, magnesium that is also present in the fluid that acts to neutralize the acids and sulfites. You will also typically find more molybedlum present which increases the lubrication properties of the fluid. The biggest difference thou is how resistant to thermal viscous breakdown they are. Meaning that over time the higher group number oils tend to not thin out over time and prolonged use which allows longer time between changing under normal loads.
In summary if you stay away from super thin oils in the number 4 group and change your oil often enough it really doesnt matter what brand you use too much. If you are looking to put the best in your ride look for the highest TNB rating and use a group 5 oil rated for your intended use. Costs are however varied greatly, which is why people still use grandpa's old valvoline 10w-30 and change it every 2500 miles.
Out of curiosity, what weight do you run in your rig, and how do you find dealers? I searched online because I'm certainly willing to try it out myself, but it seems that part of the site is "under const."...I've tried everything else, RP, AMSOIL, Mobil 1, Castrol Syn.,. Based on your knowledge, I'm curious to try it the next 5,000mi.
Dognights is correct with a lot of what he is saying. I used AMSoil in my 98 TJ and it made the valve train very noisy and the engine started to knock. Now this is NOT AMSoil's fault, but my own for not putting the correct oil into the engine. The 4.0L (OLD A$$ ENGINE) uses SL rated oils like "High Mileage" oils with a lot of ZDDP. I switched it out for Quakerstate Defy and within 2 weeks the motor ran like new again.
Now i have used AMSoil in MANY cars, but they were all sports cars or new cars. I am currently using AMSoil in my new 12 JK since the new motor is rated for it. You must look at what the motor asks for! Make sure the oil you are choosing is for your application!
Dognights, I would highly suggest sending AMSoil your story since they love to dive into researching what happen to things to improve their oils. They may even help you out.
Space
Space
I will also agree that Amsoil does have one of the highest flow rates of any of the typical oil products you might find. This however does not directly relate to thermal transfer properties. Amsoil is not a bad product, it is better then quite a few other alternatives for the same money. I however do have issue with the over the top bold performance claims, and the limited(strange) distribution and support network they have. One of the reasons I first tried it on my race bike is due to the great contingency program they had. If you race and win with a little sticker on the side of your bike using their product they basically gave you all the free oil you could use. After using the product I elected to pay for another product then use their free product if that tells anything of my experiences with it.
Space
Is it really that hard to find AMSoil in the state's? I mean you just order from AMSoil.com and you have the chance to sign up as a vendor immediately and save even more! I also am able to find AMSoil in my local hardware shops like KMSTools. If you have friends that do syn oil changes also then order from the website is actually a great deal if you split the yearly cost for vendor prices.
Space
Space
I was hoping that I missed something, but it appears that it is a little tougher to get a hold of in person. Now I am re-thinking my choice of oil so I am not sure what I will do.
