Air Conditioner is on when turned off
Air Conditioner is on when turned off in window/foot setting but stays off when in face and foot setting. I havent tried it any other settings yet.
Basically the A/C should be off when the button for the A/C is off.
Taking it to the dealer on Monday.
Any thoughts? I searched for this topic.
2008 2dr X.
Wondering if the wires are crossed with the recirculation setting since this setting is based on the airflow directions.
Want to be able to explain this in the best way with the dealer so they dont have to tear the whole thing apart
But i can say that my sunrider top isn't leaking; yet
2008 2dr X.
You blew it man, your top's gonna leak now, karma gods got me the other day. I mentioned how my softop didn't leak, next day it sprung leaks from all positions, go figure. I ain't got nuthin on your ac prob though, somebody with knowledge should hit this thread before long though.
Odds are that you have a stuck compressor relay... Happens sometimes. Had a similar issue with my wife's Caravan.
That said, make sure you don't have defog selected. The A/C runs for defogging, even with the A/C button off.
My regards,
Widewing
My regards,
Widewing
Defrog? The recirculation button is off.
What do you mean with the defogging? If i have the air circulating to the windshield and feet setting at the lowest temp; you're saying that the a/c is going to be on even if the a/c is switched to off? Hmmm. Maybe i need to reread the manual then. Would seem to be odd to do that.
It's working as it Should. All Jeep products turn on the AC automatically if air is directed to the windshield. The AC removes moisture from the air to aid rapid demisting even with the system set to hot.
And with the amount of drips inside the cab from the softtop, I need all the dry air I can get!!!
Ok guys thanks for the reply. I'm sorry that i didnt notice this before; but anyway from the manual:
"NOTE: The air conditioning compressor operates in both Mix and Defrost or a Blend of these modes even if the fan switch is not in the A/C position. This dehumidifies the air to help dry the windshield. To improve fuel economy, use these modes only when necessary."
Thanks again for your replies.
