Air bag Sensor light and dinging
Ok: Here ia another @#%@$! light and dinging going on for no reason on a 2007 Rubicon 4 door. I will check all harnesses under the seats but it looks like from previous postings, this may be a clockspring deal in the steering column? I hope not, 500.00 is pretty steep for a repair not covered as I am 500 miles over the warranty.
Any other thoughts out there. I think jeep needs to come clean on this. I only have 41,000 miles on this vehicle.
Mine did the same thing on the way to and from work the other day. I thought is was the clockspring, but my horn and cruise still worked
I did pull my carpet and replace it last weekend, so I went under the seats and pushed on every connection I saw. None seem loose, but it has been fine since then.....fingers crossed.
Is there a fuse that I can pull and replace in case that is the cause? Tried pulling battery cable, tried resetting computer and also looked for a trouble code but did not find one trouble code.
Guys, we all need to write the nhtsb so we can get a recall going. The more replies they get, the more they will know this is a serious and very common issue affecting thousands.
write them:
NHTSA Headquarters
1200 New Jersey Avenue, SE
West Building
Washington, DC 20590
give them your model jeep and a descreiption of the common clock spring airbag light problem.
thanks jason
write them:
NHTSA Headquarters
West Building
thanks jason
Mine just started yesterday. 2007 Sport with 78000 on it. But the funny thing is that it only happens when I turn left the the light goes back off till I turn left again.
mine is going in next saturday, for the second one. the first was at 30,000 and now at 64,700. purchased 5-29-2009. Do ANY other Chrysler products have this problem or only the JK?
