AC Help
AC Help
Hey guys,
So my AC in my 2013 JK isn't blowing correctly. When I drive 20+ mph cool air will slightly come out of the vents but with barley any power, when I come to a stop no air comes out at all. The fuse is good and I just replaced the blower fan motor and still nothing. Any one have any other suggestions or helpful tips?
Thanks in advance!
Thanks in advance!
If the blower motor fan is testing correctly then it's being blocked possibly by a vent or blend door. I had this on a 2004 WJ where the blend door fell off completely and laid on top of the frame for the blower motor therefore blocking it.
Originally Posted by phoebus304
The fan isn't even working, I replaced the old one and it still doesn't run.
Next would be a test light to the fuse and then harness and check for power. I believe you will get different numbers as the fan spins on higher power.
Originally Posted by YBNormyl
Blower module?
