ABS and Traction control light won’t clear
There is a large abs connector under the hood. Driver side I believe. I simply disconnected that connector block and sprayed liberally both sides with deoxit spray. Reconnected and the problem went away, never to return. Maybe a different spray would have worked. Or maybe simply disconnecting and reconnecting is what did the trick. Obviously my issue was a poor connection in that connector.
appreciate it. Going to give it a try. I’m assuming you mean that connector right next to the abs module?
How did they determine that the wiring is all ok? I had similar issues with mine (light wasn't constant though, it would come on when going over bumps or ditches) and I thought it was the sensor too, but after pulling the wiring out of the sleeve I found a spot where it was starting to break. It was the spot about a foot from the sensor where they put a tight loop into it, the wiring was all brittle and was making an intermittent connection.
BLVCK_JEEP (02-01-2023)
