ABS and Traction control light won’t clear
Old 01-31-2023, 07:29 PM
BLVCK_JEEP's Avatar
Originally Posted by rob_engineer
There is a large abs connector under the hood. Driver side I believe. I simply disconnected that connector block and sprayed liberally both sides with deoxit spray. Reconnected and the problem went away, never to return. Maybe a different spray would have worked. Or maybe simply disconnecting and reconnecting is what did the trick. Obviously my issue was a poor connection in that connector.
appreciate it. Going to give it a try. I’m assuming you mean that connector right next to the abs module?
Old 02-01-2023, 06:37 AM
peachferrari's Avatar
How did they determine that the wiring is all ok? I had similar issues with mine (light wasn't constant though, it would come on when going over bumps or ditches) and I thought it was the sensor too, but after pulling the wiring out of the sleeve I found a spot where it was starting to break. It was the spot about a foot from the sensor where they put a tight loop into it, the wiring was all brittle and was making an intermittent connection.
BLVCK_JEEP (02-01-2023)
Old 02-01-2023, 09:34 AM
BLVCK_JEEP's Avatar
they said they followed it from the sensor up, and everything looked good. I’ll make sure to ask about it when i pick it up. Haven’t heard anything from them today though so we’ll see. Also going to do what was suggested about the deoxit on the connectors
Quick Reply: ABS and Traction control light won’t clear
