87 or 91 Gas?
#61
Gas is gas, regardless of brand. All are required to have a certain level of additives in each grade. There might be slight variations in the additive packages in different brands. But all of the companies, big and small, share the same pipelines, same distribution points, and often the same trucking services, and they buy their additives from the same company in Houston, TX. And they buy their ethanol from the same corporate agribusinesss who are subsidized with your tax dollars to grow the corn for that ethanol production.
#62
I thought cheaper gas had ethanol in it and the more expensive stuff did not. Ethanol waters down gas making it give you less MPg's.
#63
WOW! I'm impressed with all the octane/brand discussion. I'd like to hear from a recent gasoline truck delivery person and get the real story on how many types of gas are in the truck delivery tank. I realize it must be regular and premium, but compartments for other "off" brands???
#64
I never use ARCO. I once had a mechanic tell me he's seen vehicles ruined simply by using ARCO gas. I don't mind Chevron, 76, or Shell. Mobil is ok, but I notice significant improvements with Shell & Chevron the most.
Sometimes I'll buy CostCo gas if I'm right there and need to fill up, but I don't know who their fuel provider is
I moved away from Exxon/Mobil a several years ago, for various reasons. I use Chevron now primarily for the Techron additive, and the fact my cousin and his wife works for Chevron. They live in Danville, near corporate headquarters. Originally a Director in corporate finance, my cousin took a job traveling the world about 15 years ago - he's been there for 30+ years.
A few years ago when I was visiting for a family gathering, I asked him about the oil business and how gas is refined, distributed, etc. Basically he said gas is all the same, with exception to the additives.... which supports what Biscuit wrote. I'm not convinced the claims that a delivery tanker has multiple compartments with different brands, grades etc. However, that claim may be valid if a single truck is making multiple deliveries and servicing common stations that use BP brands, i.e. Arco, Costco, Albertsons Markets.
I think it's a stretch however if someone is claiming a delivery tanker is making drops to Mobil, Chevron, Shell stations on a single run... with potentially nine different compartments. I say this because I worked in a Mobil service station in the 70's. We had three underground tanks and three grades. If I remember correctly the tanks were 10K to 30K gallons each, depending on the grade. A single tanker carried three grades and would drop a full load in one sitting.
.02
#66
A lot has changed in 40 years... including gas formulations and underground tanks.
The point is... underground tanks are much larger than a delivery tanker can hold. Therefore a single delivery is most likely a half or full drop.
#67
Doesn't add to the thread, but since cheap gas was brought up...
30¢ a gallon when I was driving my VW as a teenager. 19¢ a gallon in Texas when I went there to visit my brother.
(Heating oil in Maine was 12¢ a gallon.)
#68
#69
Originally Posted by Titanium Dad
I always laugh at what people say about gas. I work in an oil refinery and when the regular unleaded gas leaves our plant its at 89-91 octane. Federal law requires it to compensate what may be in the tank in the ground at the gas station. Don't buy 89 octane, it's just a splash blend of premium and regular. Same as regular basically. The only real difference in gas is the premium. It does have a higher octane but just like all gas now, it's blended with 10% ethanol like the rest. So it's not pure either. Save the cash and by regular. It's basically all the same. Just like motor oil.
#70
Yep, the trucks aren't limited by volume it is the weight that limits the capacity. Gross weight for the truck is limited to 80,000 lbs. Typical truck with tanker weighs in at roughhly 35,000-38,000 lbs with gas weight at 6 lbs/gal they are limited to only approximately 7500 gallons.
