35's on a "Stock" 2dr sport
Old 10-14-2013, 04:08 PM
gillbot's Avatar
Originally Posted by Invest2m4
Seems every Jeep is a little different. I put a 2.5" BB on my 2-door, 35's, 4.5" BS wheels. I rubbed the air dam. Two choices: trim it, or remove it. I just took it off (super easy). Jeep looks better without it anyway.
If you've got money for 35's, why not spend $250 for a TF 2.5" BB?
i decided to opt for 33's instead of the 35's. Cheaper tires, less "extras" needed and they should be plenty for me in the long run.
Old 10-15-2013, 09:56 AM
IRubicon's Avatar
Originally Posted by Ncb
You'll have to lift or go flat flares, trim and get back spacing at 4.5" or less to roll 35" rubber. You gotta pay to play. Sounds like you should go with some Rubicon take offs or 32"-33" tires.
are you speaking from experience? I'm considering doing 35's, flat fenders, and a leveling kit on my '10 rubi. I've heard that I need to trim pinch seams and the rubi rails(which I'm fine with doing), but otherwise I'm still not sure if this setup will work or not. I think it would work on a sport without disconnects, but on a rubi with the swaybar disconnected, will it still clear, or will it rub? I do wheel often and I use my swaybar disconnect often, so I'm concerned that without a 2.5" lift I will rub..?
I prefer not to do a BB, and don't want to get into a lift yet, so if this won't work I'm either forced to go ahead and get a lift or go down a size to 33's. Has anyone tried doing this?? any input would be greatly appreciated.
Old 10-15-2013, 05:11 PM
gillbot's Avatar
From what I read it's hit or moss on the lift and I wasn't willing to risk it. I sold my 35's and am going to get 33's.
Old 03-28-2014, 02:42 PM
IRubicon's Avatar
well I got 35's on mine without any lift and just flat fenders, finally. Still lifting it 2.5" but the lift hasn't arrived yetClick image for larger version
ID:	541279Click image for larger version
Old 03-28-2014, 04:13 PM
gillbot's Avatar
Looks nice. I ended up putting 32's on mine since it was easier in the long run.
Old 03-28-2014, 04:35 PM
WARLOCK's Avatar
well I got 35's on mine without any lift and just flat fenders. Finally, still lifting it 2.5" but the lift hasn't arrived yetAttachment 541279Attachment 541280
Did you have to trim your pinch seems ?
what is your wheels BS ?
Did you wheel it to see if it has any rubbing while flexing ?
Old 04-07-2014, 08:41 AM
IRubicon's Avatar
No I haven't trimmed anything, even the rubi rails don't rub. They are close, but they still don't rub
Wheels BS is 3.75", tires are 35x12.50x15 so they don't actually measure 35" tall they are under
No rubbing, I took it out and flexed it a little with no issue. I haven't been in any max flex situations yet so idk about that. I'm still lifting it, I want more suspension travel anyway, but I got impatient waiting for the lift to come from Rock Krawler and curious if they would fit without it
Old 04-07-2014, 01:09 PM
BlackdogJK's Avatar
well I got 35's on mine without any lift and just flat fenders, finally. Still lifting it 2.5" but the lift hasn't arrived yet<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=541279"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=541280"/>
You did 35s without upgrading the gears? How does it drive? Is it sluggish now? I'm assuming you have 3.73 ratio?
Old 04-07-2014, 01:10 PM
BlackdogJK's Avatar
Never mind. Just saw it was a rubi. Looks good.
Old 04-08-2014, 06:10 AM
IRubicon's Avatar
lol yeah it's a rubi, a guy I work with put 5.13 (he says) in his for 35's and continually tries to tell me how I need to change my gears blah blah. I personally love it with the 4.10's, feels better than it did on the stock size tires.
Quick Reply: 35's on a "Stock" 2dr sport
