30k service help
30k service help
just did all the fluids but on the diffs it called for like 1.3 quarts for front and 2.3 for the rear and to fill to it leaks out the fill hole. but it only took 1q for the front and 2q for the rear is that what every one else has seen. in the write up it said buy 4 quarts but i have one left. is this right?
Fill with exact amount as called for plug hole with finger any quickly tighten fill plug. Remeber also if you have a lift and rotated rear axel to correct pinion angle you may need to over fill to make sure the bearing on the output get lubricated.
