3.73's or 4.10's
JK d30's with 3.21's have the odd sized carrier. A d30 with 3.73 will use the same carrier all the way up to 5.38's.
JK d44's use the same carrier from 3.21 to 5.38.
So, since neither of your axles are a JK d30 with 3.21's, you will not need a new carrier.
But, before you regear one end, have you considered just gearing both? There are about a gajillion threads on gearing. Very common recommendations for 3.8's on 35's are to go with 5.13 or 4.88 for auto's, and 4.88 or 4.56 for manuals. Put some consideration into this before spending money on 3.73's or 4.10's.
And, while the axles are torn apart is generally a good time to think about adding traction. And you may as well think about gussets/sleeves/truss. And ...
No they are axle reinforcement. Gussets go on the c's and a truss ties the axle tubes/pumpkin better together so to speak. A sleeve is like making your axle walls thicker.
What does that run about.... I found 2 new ruby diffs for 1800....
Previous BF Goodrich tires have typically been a bit small. My 35"s were actually 34". Has this changed?
Did you calculate, or actually measured the 34.5", and at what psi ?
Gears and install kits can be had for about $650.
Arb locker is about $1200
I got a steal on my axle and stop posted what I paid because people keep asking how and all you need to do is shop around.
A Rubi axle built isn't worth over $1000 to me including the locker. Some people argue but it's only worth whatever you can get for it. Pick a price and don't budge, negotiating goes both ways
