2017 jk transmission problem
Have a problem need help!!!!!!!! I was driving my 2017 jk pulled up to a stop sign went to go and nothing I still have park and neutral. I even tried to put it into 4 high but still nothing. Has anyone experienced this or has any input on what it could be. When it happened there was no grinding or slipping in the transmission.
JpowersV23 (07-29-2024)
Yes the only gear that works is park, when I went to go from the stop sign I did not hear any grinding or anything. I thought I had spun a pinion gear in my rear end. When I got it home I put in gear and the drive shaft would not move. Im worried it might be the enteral shift linkage is broke.
The first thing to figure out is do you have a shift linkage problem or a transmission problem. There is a known issue with loosing power to the shifter and there is an override procedure. That might be a good first place to look -
