2015 steering wheel lock
Old 11-07-2014 | 06:36 AM
SabrToothSqrl's Avatar
Default wheel Lock
I think most makers dropped the wheel lock when they went to chipped keys.
Old 11-07-2014 | 07:22 AM
tcdawg's Avatar
Originally Posted by Vladimer
I thought they took out the wheel lock on the 07 to 08 transition.
My 08 did not lock and my current 12 does not lock. A guy in the club with an 07 has his steering lock with no key though.
my 08 locks
Old 11-07-2014 | 07:43 AM
Vladimer's Avatar
Originally Posted by tcdawg
my 08 locks
Weird, maybe its the month of manufacture in 08 when it switched because mine definitely did not. Don't have it anymore so can't check the date.
Old 11-07-2014 | 07:47 AM
tcdawg's Avatar
If they were changing over between 07 and 08 there may have been some 08's that still locked. I'll double check mine tonight just for giggles.
Old 11-07-2014 | 01:35 PM
kik's Avatar
kik
All 07, 08's and some 09's lock. To check it all you have to do is turn the wheel all the way to the right (180 degrees) and hold in that position. Then turn off the vehicle. It will then lock.
Old 11-07-2014 | 02:32 PM
Vladimer's Avatar
Well that's incorrect, I had an 08. Definitely did not lock.
Old 11-07-2014 | 04:26 PM
kik's Avatar
kik
This is according to Chrysler. They locked part way into 09 then it was discontinued. The wheel had to be held at full lock to the right and then turned off. You don't have to accept it, research the info.
Old 11-07-2014 | 04:36 PM
kik's Avatar
kik
This is information directly from Chrysler: As of 2009 the wrangler no longer uses a locking steering wheel across the board the owners manual hasn't been updated yet, here is the case below that is directly from the chrysler/dodge/jeep technition helpline called "star" that is where (dealer level tech's) go with unsolvable problems or questions not able to be answered via normal channels it is ONLY for dealer tech's
Case Number K05695435
Vehicle Issue Steering wheel does not lock.;Turn the steering wheel to the full right, hold and turn off the vehicle to see if the steering wheel locks.
System or Component Will Not Lock / Engage;Customer Concern (No DTCs);Column,Steering Wheel;Yes - Continuously
Recommendation 2009, Wranglers no longer have locking steering columns, compare this with another 2009 Wrangler. No repairs are needed.
Modification Date 06/29/09 2:00 PM
Old 11-07-2014 | 07:41 PM
Vladimer's Avatar
Weird, maybe mine was special I know at the time I was comparing it to the guys 07 and with the keys out I was able to go to full lock in both directions with no locking.
