2013 milage.
#21
2013 Rubicon 10A
Have a 2013 10/yr anniversary edition 6-speed with 4.1 gears and the gas mileage is terrible. I'm getting between 15 and 16 combination of town and commuting every day.
I don't have 2000 miles on it yet but the 2011 that I traded in consistently got 17-18 for the same travel routes. I did get a check engine light at around 500 miles for an 0xygen sensor(PR2097) and took it to the dealer that observed the code but could not schedule it in at that time. When I did take it back the code was no longer there. The technician that observed the code stated that it is burning rich and will decrease my MPG. However, without the code being displayed at the time of warranty service the dealer won't fix the problem. So, I'm burning rich until it trips the code again. I know it's a Jeep and not a hybrid ...but still.
KG6SLC aka Eugene
KG6SLC aka Eugene
#22
#24
JKUS 2013, Auto - after seeing this thread, just looked at mine and was shocked - I had to take a picture.. So far bone stock on suspension and tires, but I follow tire recommendation rather than Jeep on pressure (a trick I learned in my Hummer).
Attachment 481464
Attachment 481464
The pressures on the tire are only for safety rating purposes (of the tire) and do not take into account the vehicles weight. The pressures the MFG suggest do. Overly inflated tires are less safe for handling, breaking, and wet traction. Same for under inflated just poor outer wear.
BTW - That computer lies... both high and low.
#25
Higher pressure will definitely yield better mileage, but at the cost of poor tire wear. (center tread wear) At the cost of large off road tires I would rather pay a little more for fuel.
As for the computer, I don't doubt that at all - I have not found one in any of my cars that are accurate. However, I did the math about 5k in, and its not that far off - I am closer to 22mpg.
#26
Should have been more clear, I am not airing to the full Max PSI, in fact I aired down the other day when i saw 39psi on a day it hit 100. Just above what the MFG says. My Hummer says 30psi - the tires look flat, and they were starting to cup. Moreover, I gained over 6Mpg when I aired them up.. Ran close to 80k miles on the same tires..
#27
I have a 2013 with 5500 miles on it. I was wondering when others do oil changes? My manual says I will get a notification when it is needed. Is everyone old school and did it at a specific number of miles or did anyone wait for the computer to figure it out?
#28
Tons of threads on this exact topic. A common answer, and one I follow myself is to change every 5000 miles. Easy to remember.
#29
#30
Mine came on at 9500 miles, which is when I changed it. The owners manual says to change it when the indicator says to without letting it go past 10k so I follow that.
