2013 Idler Pulley
2013 Idler Pulley
Need some help. my 2013 has small squeak sound every so often. I took the belt off and checked all the pulleys. All seamed good with the exception of the 2 idler pulleys, they were running a little rough. I know whit the sealed bearings only a matter of time before they go out completely. I have been trying to find a replacement on Amazon. But nothing seams to fit my 2013. they fit all the way up to a 2011. Are these the same? They look like it in the picture, but don't know the shaft/ bolt size. Suggestions on a part number? Thanks for any help
As an interim fix try lubricating the pulley with WD-40 or comparable lubricant.
As for a replacement I would highly recommend contacting the dealership and either purchasing a replacement or get the part number from them and then search for it on Amazon. that way you know you have the correct part number.
R/
Will
R/
Will
There is a member on here who's screen name is CardID. they are a forum sponsor and a quick Bing search their site was first to come up with a bunch of parts listed. they may have a forum discount.
https://www.carid.com/2013-jeep-wrangler-engine-parts/
R/
Will
R/
Will
