2012 Rubi swaybar and lockers not working
Hey guys,
I'm here in Maob for the EJS and for some reason my swaybar won't disconnect and my lockers won't engage. I don't get any lights at all indicating anything is happening. The wiring is all intact at the switches. I did have the dash panel out when I was wiring up my compressor switch but I pulled it back out and checked for any wires or co nnectors that may have gotten unplugged. I've checked some fuses indicated on my fuse panel but everything seems fine there. I did have the center console partially off but I pulled that apart and checked for anything that could have gotten pulled.
Does anyone have any ideas other than just bypassing the relays? lol ( I can do that too)
Thanks in advance,
Bob(BTkillerr)
Thanks in advance,
Bob(BTkillerr)
Bromberg#1 (06-06-2018)
Mine do this at times. I usually have someone press the switch while I listen to see if sway / lockers engage . A lot of times, the lights won't come on, but they are engaged . Also, I find it helps that if you drive a little (slow) this helps them to engage or disco
I will have someone listen at the disco and also listen at the lockers to see if somehow they are engaging or attempting to anyway. I was wondering if there was maybe 1 fuse that would affect both or something else. Frustrating because I will need lockers for 2 of the trails this week.
I appreciate the feedback.
Bob
I disconnect my sway bar in 4Hi all the time. The locker's default is to disconnect in 4 low only. Jeep' sway of preventing the non thinkers from blowing their diffs at speed.
Lockers, 4lo only
Sway bar, front only, in any 4w setting.
