2011 - 2012 JK Parts Diagram Online
Can someone please post a link to online parts diagram PDF etc for 2011.
I am looking for a Auto Center Conole complete..
parts diagram
Here you go, parts listing for 2011 wrangler:
http://www.gmb.be/CJD_parts/CD5/Catalogs/06-09/11jk.PDF
On the console, if you have an automatic, you have to use the shifter mechanism from a 2011 if you have the 42RLE transmission as was in my case. Also order the "floor,shift bezel" as shown on page 395 in the address shown above According to the parts list, there was a 5-speed a/t offered as well, this would be the Mercedes 5-speed a/t which may have applied to overseas models, i don't know. In that case, a different shift mechanism is required to accomodate the shift-on-the-fly option. . Also, order the shift knobs.
Related to the console itself:
1) If you have the 4-door, you will have to re-use the jumper harness that connects to the rear window switches. The conector to the switches is the exact same. The switch bezel number is 1UB68DX9AA for those with the black interior. If you don't have electric windows, the bezel is 1UB92DX9AA. Also the switch itself is 68057597AA.
2) When purchasing the main console base, all rubber pads in cup holders and storage areas come pre-installed... no need to purchase separately.
3) The padded armrest does not ship with a lock cylinder or the screws to attach. I ordered a replacement lock cylinder for the glove box and it fit perfectly. The only draw-back is that is seems to be an all plastic piece and is not coded to key. The local Jeep parts guy can take your ignition key and code the new lock cylinder to math. Then it is just a matter of pushing the cylinder into the hole in the console lid and twisting, goes right in.
4) Finally, depending on whether you want the 115c power outlet option, this bezel is on page 136.I chose to go with the blank which is 1UB911X9AA on page 637
Hope this helps!
Hope this helps!
