2010 JKU - 6-spd Manual Tranny Slipping - Clutch Replaced
My 2010 Unlimited is exhibiting a slipping clutch while on the highway. I had the clutch, pressure plate and throwout replaced and the flywheel surfaced about 18 months back. JK currently has 87,000 miles on it. All had been fine until recently. While driving yesterday in 6th gear, I depressed the accelerator for an upcoming hill and the RPM's jumped up by about 750, but the Jeep didn't accelerate. After a few seconds the RPM's dropped back down and the clutch caught and it picked up speed. This has happened a handful of times recently.
Are there any adjustments that can be made at the clutch? Would this be a sign that the fluid is low in the clutch master cylinder? I had the clutch work performed by a professional mechanic that I've used for 30+ years. He knows what he's doing. Hate to go back to him until I've checked out the obvious things.
Thanks,
David
Thanks,
David
By all means check the fluid level in the brake master cylinder (it's a clear reservoir), but that won't cause slipping. Air in the hydraulic clutch or lack of fluid causes the opposite problem of not being able to fully disengage the clutch.
Best to take care of it quickly, and keep the throttle low to avoid slipping.
common reservoir...
