2010 JK Sahara Unlimited and a transmission cooler
I have the Unlimited with a tow package,. I am going to start towing a small RV and decided I better add a transmission cooler. I called my dealer and was told "you don't need one, the 2010 JK already has one built in".
Interesting. I am pretty sure I do need one one and I doubt a factory one will give good service.
Any thoughts?
I think I will go ahead and install a B&M supercooler because my dealer is less then impressive when it comes to Wranglers.
Any thoughts?
The factory trans cooler is to small and buried in the bottom of the a/c condenser out of direct airflow. If your going to be towing a camper I would definately install an aftermarket cooler.
Having found out here that the factory tranny cooler is buried in with the A/C condenser and totally away from any air flow. It may help but probably very little. Very bad engineering design.
I am adding a B&M cooler.. My dealer gave me a hartd time about it but they have never impressed me with their Jeep knowledge. I learn more here than I ever will at the dealer.
Any thoughts?
Any thoughts?
