2007-2017 JK 4 door compatibility
Just bought a 2007 Jeep Sahara unlimited 4 door. It didn’t come with a top or doors.
I put a Smitybilt soft top on it already and I found a set of used manual doors off a 2017 Wrangler 4 door that are pretty local for a decent price.
Im just wanting doors for the winter as this is just a run around Jeep. It’s not a daily by any means.
i have searched and only came up on one thread that mentioned they could possibly work.
I don’t mind if the door interior panels don’t match good, as long as they will close without hitting anything and latch and seal ok and fit the door frame.
Any help is appreciated
They will close, they will latch, and you will be protected from the rain. As far as contacting the dash- I don't believe the two will touch (put my 2010 doors on a 16 to test for leaks), but you'd have to verify.
PS: the wiring harness will be different, but that doesn't seem to be an issue for you if you just want protection from the elements.
