2 dr soft top screw part number
Does anyone know the part number for the screws that connect the soft top to the bracket on the roll bar. I dropped one of the little torx tip screws and cant find it. Havent had any luck finding a part number.
Thanks
Thanks
Location: Hangin in the sunshine state....staging forum..
I temporarily lost mine once, you can get regular hex bolts at home depot, they are they are 6x20x1 mm, 4 new ones from home depot to all match will probably be cheaper then one bolt from a dealer
The 6x1x20 screw attaches the bracket to the roll cage, not the top bows to the bracket. Someone else posted a thread about this screw recently. I posted up a photo with dimensions. Here is the thread link, scroll down to post #4 in the thread, you should be able to find these in a good hardware store.
https://www.jk-forum.com/forums/stock-jk-tech-12/soft-top-hardware-help-77961/
https://www.jk-forum.com/forums/showthread.php?t=77961
If you want to get a new factory one, the part number is 6036311AA. They're actually the same between 2 door, 4 door and 97-06 TJ and LJ.
EDIT - corrected part number, had the wrong one before. My apologies to the OP.
My TJ didn't have screws, it had pins with hitch pin clips to attach the top to the bracket. The 6503159 part is the one that attaches the bracket to the roll cage, not the one that attaches the top to the bracket.
As for the part number, I double checked and you're correct. The right part number is 6036311AA
