1st gear jumping
Old 10-05-2011, 05:20 AM
Jawhn7's Avatar
Default 1st gear jumping
Have an 07 jk unlimited... Has 43k miles and lately been jumping out of 1st gear... Anybody else have this problem? Is it covered under warranty? Any help would be appreciated
Old 10-05-2011, 05:46 AM
jdk
jdk's Avatar
It's a common problem about 99% of the 6 speeds have, mine included. Some guys on here have had it fixed under the warranty, but I was told my Jeep was highly modified and no warranty work could be done. So take it to the stealership and give it a shot.
Old 10-05-2011, 06:09 AM
1stjeep.ro's Avatar
Im currently sitting at the dealership with my Jeep for the same problem... they told me the release bearing and 1 & 2 gears need changing. I only have 27,000 kms Warranty FTW.
Old 10-05-2011, 06:19 AM
Jawhn7's Avatar
Guess i will be calling the stealership today
Old 10-05-2011, 06:42 AM
JK-Forum Founder
wayoflife's Avatar
as mentioned, a very common problem. we still have it on our white jk and it can be frustrating.
Old 10-05-2011, 06:43 AM
Jawhn7's Avatar
What is it that causes it? Just so i know what to tell the stealership
Old 10-05-2011, 06:50 AM
mgoony's Avatar
Is it body lifted or stock?
If body lifted I took a dremel and removed some of the plastic material in the gearbox which was making contact with the rubber boot. So far it has fixed the issue and I havent jumped out of gear for a while now.
Old 10-05-2011, 07:02 AM
Jawhn7's Avatar
Stock as of now... Have lift... Wheels... Tires not mounted yet
Old 10-05-2011, 11:14 AM
geman's Avatar
Please dont take it the wrong way but knowing that you have the same issue as i do gives me some relief. If an expert as you has the same issue that i have makes me feel less bad.
For the rest, there is a TBS (21-001-10 REV A) already. Havent been able to do it since im in Mexico and apparently numbers dont match but you may have better luck.
TBS attached
Regards,
ID:	219524   Click image for larger version
ID:	219525   Click image for larger version
Old 10-05-2011, 11:17 AM
yo_marc's Avatar
Are you guy'es inner shift boots in place?
I've heard that they can be out of place from the factory.
With that said, mine is in place, but will occasionally fall out of gear when it's very cold out. Like, 20*F, or below. For whatever reason, it didn't do it all last year though.
Quick Reply: 1st gear jumping
