15W40 Heaven!
#31
You'll never have a reliable baseline for comparison if you keep switching brands everytime you change your oil. IOW, the oil analysis information is basically worthless.
#32
Quick update here. Have done a good few thousand miles here now since putting in the 15W40 including a long road trip so I checked the oil level & pulled the PCV line to check for excess oil contamination. Hasn't used a drop (according to the dipstick; wont know for sure until I drain the sump at the next change & measure how much comes out) and the PCV line is still bone dry instead of dripping with oil, so the thicker oil has stopped being sucked up into the intake.
So in summary, just the results I had anticipated when I made the change to 15W40. Motor still runs smooth & quiet with all the former ticks & rattles disappearing completely and is generally much happier running this viscocity given the hot climate I am in. It's a shame I didn't run a series of oil analysis tests when still on the thin stuff so I could know scientifically what differences in engine wear the 15W40 makes.
#33
#35
The reason I changed to a higher-viscocity oil is that I am in a hot coastal climate (summer temps of 100-110F, dead-of-winter temps rarely if ever approaching freezing) and the thin oil that Chrysler specifies was leading to higher oil vapourization and consumption through the PCV system and inadequate protection at higher operating temperatures. Other manufacturers here where I am specify 15W40 for motors of similar design to the Crysler 3.8L iron block pushrod V6, with 5W30 specified as the winter fill for alpine areas only.
In fact, every other vehicle I've ever owned (and those I haven't owned but happened to look at the owners manual) has specified different weights of oil for different operating temperatures (my Mercedes specifies no fewer than 5 different weights depending on ambient operating temperatures). Chrysler just seems to have a "one size fits all" attitude to it's specified oil fill for it's vehicles which is heavily weighted towards thinner (low viscocity) oils purely for mileage reasons (in the federally mandated 36hr engine bench test, motors running the thin 5W20 get slightly better mileage so Chrysler specifies this weight in order to help them achieve their CAFE consumption targets for the fleet).
#37
I changed my oil this morning since the "change oil" signal flashed yesterday @ 21,145 miles. I used 6 delicious quarts of regular Castrol 10w-30 instead of the normal 5w-20. My engine is finally quiet! No more engine clatter with acceleration going up hill. Why did I not do this before? I have been trying all different types of gas to see if it would help when all along it has been that water-like 5w-20 oil.
#38
I am not sure I can believe that your Jeep is faster after an oil change. That really is an extreme jump to make. A heavier oil offers more protection. A light weight oil is usually what will allow an engine to produce more power and economy but at the sacrifice of less protection.
I myself am switching from 5w-20 to 5w-30 weight. Currently using Mobil 1 Advanced Synthetic oil and a Napa Gold Oil Filter made by WIX, since switching to a Synthetic oil 8 months ago, I have seen a major difference on how my engine sounds better , longer time before dry starts,etc.
I do have one question though,, What is the true meaning of the first number ex: 5w labeled on motor oil. I thought it was the weight of the oil's viscosity referred to when the engine is first started, then the last 2 digits meant "IE: 20 or 30" took over when the oil is warmed up form idiling and now is reaching the higher end of the oil's operating characteristics under varying conditions,, temperature, towing, long idle, large hills, etc. Is this correct in a non technical way? lol.
Thanks,
*** SKULL_FACE ***
#39
Thanks,
*** SKULL_FACE ***
5W-20:
It behaves like 5 weight when cold, and like 20 weight when hot.
