15W40 Heaven!
Old 12-23-2011, 07:57 PM
  #21
burnout88's Avatar
I am not sure I can believe that your Jeep is faster after an oil change. That really is an extreme jump to make. A heavier oil offers more protection. A light weight oil is usually what will allow an engine to produce more power and economy but at the sacrifice of less protection.
Old 12-23-2011, 09:00 PM
  #22
007davidjames's Avatar
Originally Posted by ronjenx
What does this mean: "Just did the same hung"?
There were many variations of pcv systems over the years. What do you have in mind?
Thing. Phone changed thing to hung
Old 12-23-2011, 09:04 PM
  #23
ronjenx's Avatar
Sounds like a Freudian phone!
Anyway, can you comment on the old style pcv routing?
Old 12-24-2011, 05:50 AM
  #24
Dronac's Avatar
Originally Posted by zstairlessone
Just wondering what elements Blackstone reports on. Do they just give wear products or can you see the additives also (Zinc, Potassium, Calcium etc). If you get the add-pack also, checking the results for the different oils will tell a larger story - how the different additives seem to be helping - anti wear, dispersant etc - keep our poor engines alive
Indeed.
Old 12-24-2011, 08:07 AM
  #25
3 tons's Avatar
I've taken a different tact by blending 50/50 5-20 & 5-30 (3 + 3 qts) of same brand synthetic...I agree that 5-20 is too light....This blend makes for a good overall compromise & balance, engine doesn't rattle. So far I'm very pleased with the results.
Old 12-24-2011, 04:54 PM
  #26
WilKJ's Avatar
Well as long as I save my receipts , shell well warranty my engine for 500000 miles..supposedly
Old 12-24-2011, 08:30 PM
  #27
Wood8176's Avatar
Default Neat Report!
Originally Posted by Dronac
Indeed.
Big picture of report was here...
Just curious, it was interesting to see they flagged the copper as increasing; did they mention anything about the molybdenum? Not to alarm you but the moly increased by 50%. Aren't the piston rings made of moly? Is that just normal wear and within their expected range? Will you post your next report too?
Old 12-25-2011, 01:26 PM
  #28
Dronac's Avatar
I used Royal Purple that time, which has a boat load of moly. Yeah, I post every report I have done. I'm doing another one in about a month or so. I ran a second fill of Royal Purple 5w-30, and will try something else this time. I'm not sure if I will go lighter or heavier in oil weight. I think I'v seen every JK UOA on the internet, and they all seem to show unusually high copper wear. I'm not too concerned about any serious failure, but I am curious. IIRC, two components that often use copper are the bearings and cams. Considering how these engines often develop a noisy valvetrain, I would think it's possibly cam wear.
My JK is a 2008, but it has a 2010 short block in it due to a spun bearing under warranty. IIRC, most of the spun bearings we have heard of were all 07-08 models.
Old 12-26-2011, 05:31 AM
  #29
johnyrrr's Avatar
subscribing
Old 12-26-2011, 07:02 PM
  #30
Rockstar007's Avatar
funny post
Quick Reply: 15W40 Heaven!
