07 Sahara oil consumption 80k ...options?
So it looks like I am in the middle of the oil consumption issue now. I'm burning through oil at more than 1qt per 1,000 miles. My JK is just a tick over 80,000 miles. From everything I read on here, it is a ring issue. I am also going to be checking my timing chain cover.
Can anyone provide me any additional items I need to check? I don't think I have the lifetime warranty as I bought this JK 2 years ago with 50k on the clock.
If I am doing anything with it, I will be rebuilding myself. Any input would be appreciated.
Thanks!
Thanks!
I would recommend trying a thicker motor oil like 10w30 and see if it slows any. Also put in a new pcv valve. Make sure there is no coolant mixed in with the oil. You might even look at installing an oil catch can, which mounts inline on the pcv hose, that way you can monitor how much oil is blowing through there
Project-JK.com - Jeep JK Wrangler Resource » TSB - 3.8L Engine Oil Seepage Due To Front Timing Cover Surface Porosity
Not saying 100% that those options wont help you, but I can say for sure they did not help me.
